First Buderus G115-WS3 cleaning
imhereallweekya
Member Posts: 20
Like a typical Buderus with a Riello, it looks awesome!0
Thats good to hear I didn't have a baseline to compare it to. I didn't get into using the brushes to clean the chambers yet, I only vacuumed out the accumulated ash in the bottom as shown in the picture. I just bought the cleaning brush set for the Buderus boilers and was curious how to open the door. I will give it a proper sweeping in the spring.0
That's what all oil-fired boilers should look like after a year's service. If they're dirtier, there's a problem.
I just serviced two units today, that we serviced last year, and that's about all I had to clean out of each one. Shows what proper burner set-up can do.All Steamed Up, Inc.
Consulting0 -
Thanks, thats good to hear. I am planning on doing all the maintenance myself because I enjoy it. Is the red in the ash from the oil dye?0
Watch the placement of the baffles when you remove them. The bottom one's sit in notches to adjust draft. Put them back in the same position.0
Oh yes, I took many pictures of those baffles :-) I have the Buderus installation manual and I was reading it and how you can adjust those baffles to increase or decrease temps. Very interesting but I will surely put them back as they were.0
