First Buderus G115-WS3 cleaning
imhereallweekya
imhereallweekya Member Posts: 20
edited December 2017 in Oil Heating
Hello , I have a new system installed June 2016. It is a GW115 with a Riello F3-40 burner. (.55gph 60A nozzle). I opened it for the first ti me here are some pictures. Not much ash considering its been in service for 18 months for DHW and heat. How does it look to you all?
Robert O'Brien
    HVACNUT Member Posts: 7,188
    Like a typical Buderus with a Riello, it looks awesome!
  • imhereallweekya
    Thats good to hear I didn't have a baseline to compare it to. I didn't get into using the brushes to clean the chambers yet, I only vacuumed out the accumulated ash in the bottom as shown in the picture. I just bought the cleaning brush set for the Buderus boilers and was curious how to open the door. I will give it a proper sweeping in the spring.
    Steamhead Member Posts: 18,175
    That's what all oil-fired boilers should look like after a year's service. If they're dirtier, there's a problem.
    I just serviced two units today, that we serviced last year, and that's about all I had to clean out of each one. Shows what proper burner set-up can do.
    Consulting
  • imhereallweekya
    Thanks, thats good to hear. I am planning on doing all the maintenance myself because I enjoy it. Is the red in the ash from the oil dye?
    Watch the placement of the baffles when you remove them. The bottom one's sit in notches to adjust draft. Put them back in the same position.
  • imhereallweekya
    Oh yes, I took many pictures of those baffles :-) I have the Buderus installation manual and I was reading it and how you can adjust those baffles to increase or decrease temps. Very interesting but I will surely put them back as they were.
