Calculating riser's air volume when balancing a system
Hi all,
New to the Wall but old to steam... I am doing some balancing and using Gerry Gill and Steve Pajek's write-up. Very helpful thank you! Their guidance discusses a lot about runout air capacity and adding that to the individual radiator EDRs to get the amount of air to vent in say 3 min. at 1oz. My question is "why not calc. the riser volumes too?" In my case the risers contain a lot more air than the runouts? The additional calculation is easy but I cannot understand why to not include when selecting vents.
Thanks!
    Steamhead Member Posts: 18,859
    If the riser is that tall, more than a couple floors, it's a good idea to vent the riser separately from the radiators. The last pic in our Find a Contractor ad shows one way of doing this:
    Semi-retired
    Circa1902
  • BobC
    BobC Member Posts: 5,576
    edited December 2017
    How tall are your risers? A 1-1/4 pipe has about 0.0104 Cf per running foot while a 3 column radiator has about 0.025 CF per unit of EDR.
    So a 30 EDR radiator has 0.75 CF of air while 20 ft of 1-1/4 pipe has 0.21 CF of air. If your rsers are very long @Steamhead suggestion is a good one
    Bob
    3PSI gauge
  • Biocellar
    Biocellar Member Posts: 3
    Thanks, all risers are about 22', just thought it odd that the Balancing Steam Systems paper spends so much time on runouts that in my case are 12' when the risers are 2x. Didn't know if I was missing something.
    EBEBRATT-Ed Member Posts: 20,970
    Your right. It's probably just a terminology thing. Pipe is pipe it's all got to be vented.
    As others have mentioned tall risers, including the runouts and the radiator may not be able to be vented properly with a simple radiator vent. Sometimes you can put two vents on a radiator.
    best approach is venting the tops of the risers as @Steamhead & @BobC have mentioned
  • R Dougan
    R Dougan Member Posts: 42
    There's also this elegant little solution
    Circa1902
  • gerry gill
    gerry gill Member Posts: 3,084
    you would calculate it and divy it up with the radiators unless its vented separately.
    gwgillplumbingandheating.com
  • I think it would also be possible to remove the bonnet of the valve, and drill and tap for the air vent. With the stem removed, this does not permit the radiator to be valved off, but how often is that feature needed?—NBC
    BobC
  • Biocellar
    thanks all! Well, I have done all the math and it turns out my perfect radiator vent doesn't exist! #Sharktank opportunity... I need a vent capacity right around .22 @1oz CFM. Don't like variable vents so Gorton let me know when you build a "B" vent!
  • Try putting identical larger vents on the top radiator on each riser, and you may not have the problems described if the vents are not too big. Those vents with replaceable orifices make this easier. If the problem with steam racing through the radiator, and only removing part of the air, then you can put the vent on the valve.
    Figuring out the volume of the risers is of scientific interest, but to get steam up to each rad simultaneously, you need to balance the resistance to the escaping air between main vents, (low resistance/back pressure), and rad vents, (higher, but IDENTICAL resistance/back pressure).—NBC
