What is this item on a Gravity System???
Kerr
Member Posts: 2
What is this red item and how does it work??? Thanks!
That looks like an old Honeywell Heat Generator. You can find an explanation on how it operates on the main page. If it hasn't been touched, that thing should have a lot of mercury in it
https://heatinghelp.com/heating-museum/mark-c-honeywells-patent-for-a-new-type-of-tee/You can have it good, fast or cheap. Pick two0 -
Thank you...I believe you are correct...I couldn't remember enough about it to remember where to start! Thanks again!0
There is a story about that mercury heat generator that should be in the "Heating Hell" category.
Some one had one spill one floor up IIRC. Whole house ceiling turned into a very expensive toxic clean up project.
It could probably be safely cut out and carried out of the basement for disposal.
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
