hydo therm boiler flame keep cycle off
lubu726
Member Posts: 3
in Gas Heating
I have an old hydro therm boiler that having trouble where the flame keep cycle off after couple mins. Im clueless when it come to these so i look at a youtube vid where they said to bleed the air out so I did that. But even after that done, the boiler still have the same issue.
If anyone know what might the problem or give any tips thank you
How many hydrotherm boilers are there? Most have a Honeywell aquastat on them. Pull the covers the aqua stats and check to see if ther is a small white dial that would be your differential for your burner set it to 10-15 it’s probably set at 5f. Also are you usng the hydrotherm out door reset panel?0
Is the pump running? Are the rads hot. Is the boiler piping to hot to hold?0
