EOS-KLM-115
Zoggi
Member Posts: 1
HI. need help please on how to wimterise an EOS sollar collector unit that is used to heat the pool. Emailed the company and no luck.
I am in canada, so the snow season will be upon us soon.
Any help is appreciated
Does the pool water go directly to the collector array? Or is there a plate or tube heat exchanger in the piping loop.
Sometimes the collectors are a glycol antifreeze loop, pool water does not go to the piping and collector.
Pictures of the mechanical room piping would help determine what you have.Bob "hot rod" Rohr
Living the hydronic dream0
- 19 Recall Announcements
