Desert Springs Humidifier
BigRob
BigRob Member Posts: 332
Does anyone have experience with these units:
http://www.desertspringproducts.com/desertspring/index.asp
The rotating discs make conceptual sense, but I need feedback on the effectiveness.
My water is not conductive enough for a steam generator, unfortunately. The home is a second home and not used too much. The heat and fan is only run when occupied. Is a bypass unit even worth the trouble if we're there mostly 2 or three days at a time?
