Zone Valve/Balancing valve combination.
Harvey Ramer
Harvey Ramer Member Posts: 2,281
Anyone know if this is available?
  • Dan Foley
    Dan Foley Member Posts: 1,268
    Danfoss AB-QM
    Harvey Ramer
    hot_rod Member Posts: 26,545
    Are you looking for a PICV or just a manual balance>
    Pressure Indépendant Control Valve combines an on off function with pressure independant balance, auto balance so to speek. Any zone valve with a pressure independant balance down stream accomplishes this.
    Chose the brand and type of ZV you like and add a 127 AutoFlo valve to it.
    Depends on what type of control you are looking for.
    Harvey Ramer
  • Harvey Ramer
    I have to add a radiant zone to a remote manifold station. The manifold station is home built with 2" pipe and 3/4" radiant tubing, no head loss to speak of. The radiant zone I am adding has a head loss of approximately 6'. There will be one pump with 2 zone valves, since it is a minitube injection system. For that reason, I need to impose a flow restriction on the original manifold, and balance the 2 radiant zones. I have limited space, which is why I am looking into a combination zone/balance valve.
