Why are radiators painted silver?
HeatingHelp
Administrator Posts: 723
Ever wonder why so many of the old radiators you see are painted silver? Paint that contained flakes of metal (aluminum or bronze) had a way of cutting a radiator’s output by 20 percent so they started painting radiators that distinctive silver color.
My father always had a can or bronze or aluminium paint in his truck.0
Thanks for providing a concise answer. Since buying a house with radiators painted silver, white & pink 23 years ago, I've been trying to find out what one color I should paint them to achieve the most efficicency.
Now, can someone tell me how to remove the chipped & worn (presumably latex) paint with rusting metal underneath in the bathroom? Then, what should I seal it with to maximize efficiency & prevent more rust?
Thanks.0 -
@TMcGroy - A lot of pros recommend sandblasting it or having it taken somewhere to be sandblasted and powder coated. Here's more info: https://heatinghelp.com/blog/how-to-paint-an-old-radiator/
President
HeatingHelp.com1 -
I've been hashing this subject over with some friends who are engineers. They contend that radiation is such a small component of the output from a cast iron radiator compared to convection that paint color would have a negligible impact on radiator output. Radiators may have been painted silver because a lot of folks believed in a heat retention theory, but it is likely not true, based on what my engineering buddies say, that reflective paint reduced heat output noticeably (or that another paint color then increased radiation noticeably).-1
- 120 Geothermal
