Suggestions for Radiant Heating + Cooling systems
seattleradiant
Member Posts: 2
I’m building a new ~4500 sq ft home in the Seattle area and would love to do a radiant heating + cooling system. Any suggestions on which companies / systems to check out? I’m getting an estimate for an Ahhm radiant + Zehnder ventilation system but is rather pricey.
It's all going to be pricey...for superior comfort.
If you have the drawings, I'd recommend you hire someone to design the system, so you can bid it out to a competent contractor.
It's more about the design, and the execution.There was an error rendering this rich post.
