Governale radiators
namahs
namahs Member Posts: 5
I'm in the process of upgrading to a hot water circulation heating system. My contractor is recommending to install the Governale recessed Radiator - Cast-Iron. I can't seem to find any real world review on this radiator, anyone here either installed this or have this in their home? If not, which other cast iron radiator brand would you recommend? Thanks in advance.
http://www.simplyplumbing.com/174666-recessed-radiator.html
  • BrickeyHeat
    BrickeyHeat Member Posts: 5
    I have used the Governale and had two factory leaks in them. They are made in China. Try the Weil Mclain cast iron. They are much better quality.
