Anyone know where to find radiator plugs and bushings?
The Steam Whisperer
Member Posts: 1,215
Looking for the nice Hex radiator plugs and the standard hex recessed bushings
your local plumbing supply house"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
Are you looking for black steel or iron?The Steam Whisperer said:Looking for the nice Hex radiator plugs and the standard hex recessed bushings
Ward manufacturing builds all sorts of recessed and raisied hex bushings. Finding the odd ones on shelves is not always easy. get the part number from the ward online catalog and do a google search. I've found odd ball fittings on E-bay.
Love that site you recommended I bookmarked itDanny Scully said:
Thanks, I forgot about OCS... don't see the nice recessed bushings like on the old radiators, but Ill look at ward and anvil in more detail. Found the nice hex caps and pedestals from Governale.
The Steam WhispererTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
find these in brass and stainless also.
https://www.pipestock.com/malleable-iron/georg-fischer-threaded-iron-pipe-fittings/black-iron-pipe-fittings/plug-recessedBob "hot rod" Rohr
Not good these are British Standard Pipe Tapered. Shape of thread is 55º instead of 60º , threads are 11per inch vs NPT 111/2.hot rod said:find these in brass and stainless also.
Yes, I've been finding that most of what I am looking for is BSPT, not NPT. Makes me wonder when American Industry is going to wake up to the fact that there is a HUGE installed base of older steam and hot water systems that is being essentially ignored. It's really insane that you it seems you can't even get basic pipe fittings to properly install a radiator!
Here in Chicago, I bet at least a third of the housing units are steam heated and a whole lot are hot water, yet we are the only company that specifically targets the steam market. I bet the percentage of steam is even higher in eastern markets,since hot water has been being pushed here in Chicago since the 50's and 60's. For a good deal of the larger buildings, steam is the only sensible choice due to the engineering limitations of hot water and forced air in buildings taller than 4 to 5 stories and no place to vent equipment but up in high density areas.To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
@The Steam Whisperer I've found Mid-Lakes Dist. on Adams will special order anything they don't stock from Ward for me. Might take a few days, but they've been able to get me just about anything from the Ward catalog.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
