Help find a heat exchanger.
plj
Member Posts: 2
in Gas Heating
Hi
I have a pool boiler (Certikin Genie MB50C) which has finally decided to pack up. I think the issue is the Heat Exchanger. TO confirm I remove the condensate waste with the heater on but not lit (so no heat basically but as it won ignite anyway that's not surprising !). The water is flowing out of the condensate waste with vigour.
The heat exchanger in this boiler is a Giannoni MB30-45-055-00 but Certikin direct me to pool suppliers who are charging £1200 for this part ! I just don't have that kind of money so I am hoping someone can help me identify where I can get this item outside of a pool centre.
I have seen similar Hat Exchangers used by Baxi, Potterton and Vaillant but not this specific size but am hoping this I the same as used in other non-pool related boilers.
My contact with Gannoni (now Sermeta) has proven futile ...
This is for a 50 Kw bolier (170,000 BTU).
I can upload a photo if
How old is theboiler? Are you using chlorine or salt?0
Pool boiler is 10 years old been used with Chlorine. Actually looks like Malvern Boilers make these for Certikin but neither they nor Certikin will deal direct leaving me with a best price of £922 to replace the heat exchanger via a pool company .. Then there is fitting of course..
- 116 Geothermal
- 15.8K Strictly Steam
