EDR of this radiator?
I have a radiator I can't identify. Seven small tubes, 12" wide, 38" tall. It's on a hot water system, originally gravity. I have three like this, various section counts.
  • MilanD
    MilanD Member Posts: 1,162
    This should be pretty accurate.
  • steamedchicago
    steamedchicago Member Posts: 73
    It, and any other reference I've found, doesn't cover 7 tube radiators 38" tall. I can extrapolate, but I'm hoping someone has a better guess.
  • MilanD
    I realized after posting it doesn't have the height. Perhaps someone here has the EDR book.
    Steamhead Member Posts: 18,397
    There's no name visible, but I think National was the only company that made a 38" tall, 7-tube radiator. Ratings are in Dan's "E.D.R.".
    Consulting
  • steamedchicago
    Thank you. There's a 1926 (year the house was built) national catalog available at archive.org https://archive.org/details/NationalBoilersAndRadiatorsCatalogNo.35_517 The style is called 'aero'.
    That tells me 7 square feet a section, which was what I'd extrapolated from the tables I'd found. That seems oversized for the room it came out of, but we knew that.
    All of my radiators are this style, in various widths, heights and lengths, except in one bedroom, which has a column type, and a basement one which is a more deco style (and a recent addition).
    Catalog says lengths to 32 sections; I have a seven tube, 38 section, 20 inch high radiator in my living room. I wonder if it was specially ordered, or the builder put it together from two smaller ones.
