BAXI Luna HT 380 - hot water interrupted
vml
Member Posts: 1
Hot water is interrupted mid shower. New problem. There have been many others resolved. (Not a fan of this boiler but it is what I have...) Any ideas why hot water is not holding. It eventually comes back. Thanks for any suggestions.
When you turn on the hot water, it pushes a diaphragm in the Baxi which closes a switch to turn on the burner. Check the diaphragm to make sure it's not compromised; replace as necessary.
http://www.bing.com/images/search?view=detailV2&ccid=W73NK1UV&id=54601D547764CAAF962FD957A42BE6DBB8A7ADCB&thid=OIP.W73NK1UVkIzbiTG1qwUjEgEsEs&q=baxi+ht380+parts+diagram,+diaphragm&simid=607990692989374294&selectedIndex=10&qpvt=baxi+ht380+parts+diagram,+diaphragm&ajaxhist=08.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 116 Geothermal
- 169 Indoor-Air Quality
