Finding Carrier product ratings
zepfan
Member Posts: 442
Does anyone know of a way to find AHRI ratings for Carrier air conditioners? They do not have them on their website, while most manufacturer's have them in the product data for their equipment. Carrier just directs you to the AHRI directory, and unless you have all the information of the unit the site is of not much help. Thanks to all.
call them its probably on a different site, alot of manufactures do this"The bitter taste of a poor install lasts far longer than the JOY of the lowest price"0
You do need all of the info but the AHRI site works well. If a coil only match, need outdoor unit and indoor coil. If you are using a high efficiency blower motor on a furnace to get higher SEER, need to put in the furnace model # as well.0
They now have a system match tool on the dealer side now.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 47 Industry Classes
