New Home, Hydronic Heating Questions
Thanks for the insight fellas, I'm going to do some more research.0
Yes Larry is correct. Floors should feel almost neutral. The warm floors were back when fuel was cheap, and insulation scarce.Larry Weingarten said:Hello, The idea of warm floors is fun, but as your house gets more efficient, the cooler the floors will be as there simply is less heat required. You may feel those warm floors when it's really cold outside, but not so much the rest of the time. I did radiant walls in my place...
Your, Larry
- 52 Job Opportunities
