New Home, Hydronic Heating Questions
13»
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,034
    Hello, The idea of warm floors is fun, but as your house gets more efficient, the cooler the floors will be as there simply is less heat required. You may feel those warm floors when it's really cold outside, but not so much the rest of the time. I did radiant walls in my place... ;)
    Your, Larry
    Gordy
  • RedNeckRacin
    RedNeckRacin Member Posts: 28
    Thanks for the insight fellas, I'm going to do some more research.
  • Gordy
    Gordy Member Posts: 9,546
    edited June 2017
    Your, Larry
    Yes Larry is correct. Floors should feel almost neutral. The warm floors were back when fuel was cheap, and insulation scarce.
  • Gordy
    To add to @hot rod last post. Oil canning, clicking, etc in the middle of the night usually will make some crawl the walls. Usually at night is when the loads come for sure, and the system runs.
