Caleffi hydrofill debut....
kcopp
Member Posts: 4,524
I used this neat tool today. Fills the system w De-ionized water from the house water supply. The water quality is super crazy good after running through the resin. It will take a bit getting used to the reduction of pressure but the wait is certainly worth it.
I was graciously lent this from FW Webb in Dover,NH.
Good evening kcopp I work for F W Webb in Allentown PA.
You said the our branch in Dover NH let you use the Caleffi filer cart who is your inside contact person at this branch? Plus was there a rental fee for using the Caleffi filter cart? Where did you buy the IBC Boiler from?
I sent you a PM.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
