Santfin VHS vs Burnham ESC
NYplumber
NYplumber Member Posts: 503
Hi there WALLies,
Comparing the two boilers for a client. The Slantfin seems to have less proprietary parts. The Burnham can take a lower return water temp.
Please post your input on which and why. Direct vent is required however room air is fine.
Discuss.
:NYplumber:
  • lchmb
    lchmb Member Posts: 2,997
    Either boiler I would go direct vent. I lean towards the Burnham but think the biggest thing is support for the product in your area. Can you get parts and help if needed...
  • NYplumber
    The nice part about the Slantfin is that it can take a standard commonly found Honeywell aquastat. The Burnham is also a Honeywell however not found as much locally.
    The on board IQ system is nice however the Burnham requires one to purchase a ODR card while the Slant fin comes standard.
    :NYplumber:
