Burner plate
panther
Member Posts: 6
in Oil Heating
I had a housing inspector looked at my oil burner well McLain from the seventies and he said that's missing a burner plate I'm not so sure he knows what he's talking about is there a burner plate that I don't know about thank you
Usually that means the iron plate where the burner is mounted. Take a pic of yours and post it- let's have a look. I'll bet it's a 66 or 68 series.
Are you sure he didn't say "rating plate"?All Steamed Up, Inc.
Consulting0 -
>> Good catch. The 66 series has the rating plate right above the CI front plate. Probably fell off years ago.
I just mentioned in another thread, a guy with a 66 series McLain, 30+ year old boiler. Maybe it's time to upgrade your system.
Do you have natural gas? Look into a mod con to save $$.0 -
Same OP in both threads.
And, is this a steam or hot-water system?All Steamed Up, Inc.
Consulting0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
