Burner plate
panther
panther Member Posts: 6
I had a housing inspector looked at my oil burner well McLain from the seventies and he said that's missing a burner plate I'm not so sure he knows what he's talking about is there a burner plate that I don't know about thank you
    Steamhead Member Posts: 18,500
    edited April 2017
    Usually that means the iron plate where the burner is mounted. Take a pic of yours and post it- let's have a look. I'll bet it's a 66 or 68 series.
    Are you sure he didn't say "rating plate"?
    Consulting
    HVACNUT Member Posts: 7,451
    >> Good catch. The 66 series has the rating plate right above the CI front plate. Probably fell off years ago.
    I just mentioned in another thread, a guy with a 66 series McLain, 30+ year old boiler. Maybe it's time to upgrade your system.
    Do you have natural gas? Look into a mod con to save $$.
    edited May 2017
    Same OP in both threads.
    And, is this a steam or hot-water system?
    Consulting
