Return Air Base Height
tomjo
Member Posts: 2
in Gas Heating
I just had my furnace and AC replaced. New furnace is 110,000 BTU Carrier 58ctw-110. An 8 inch return air base was supposed to be installed but wrong instructions were given to the installers and they only put in 4 inches. The HVAC company owner is now telling me an extra 4 inches won't make much difference, but it will mean 24 inch filters instead of 20 inch filters since he can only cut a 16 inch hole in the side of the furnace. And 24 inch filters are harder to find. Should I make him fix his mistake?
It's hard to visualize what you mean but I would say your installer is trying to cheap out on the correct fix. How many air filters and what size/ How many ton of air conditioning?0
One air filter, 4x20x25. 3.5 ton AC.
I agree with @Harvey Ramer0
It'll be fine. The 8 inch will restrict tooth anyway0
The 8 inch will restrict too much anyway0
