mechanical v. electric probe type LWCO
steamfitter
Member Posts: 156
On HW boilers, is there a preference on which type of LWCO there is?
Is there as much need to blow down the Mech LWCO on a HW boiler as there is on a Steam boiler?
On hot water I think most would recommend a probe type control.
No, hot water electronic probe controls need to be tested with the test switch which most have. The probe should be removed and cleaned 1 a year.0 -
Why are mechanical LWCO not as common in hw boilers?
If they are used, would they have to be blown down as much as those on steam boilers?0 -
IMO they would be hard to test as you need the float to experience the water drop. So maybe never get blown down and tested.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 956 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
