Hot water showing up in Hydronic airhandler coil, when no heat is called for.
HGR693
Member Posts: 3
Hello,
Have a SMART tankless (60Gal) unit, boiler fed. Boiler also feeds two hydronic coils for heating the home. My second story coil, has hot water in it, whenever the boiler is running, even though the TACO cir pump is not running. Cast iron fitting at this TACO pump, is reading around 120* while other zone ( first floor) cir fitting is less than 100*. What might be the problem. Thank you
not that i know about. There are three Bell & Gossett Flo-Control Valves, coming off the boiler, about 6' off the ground. They have NEVER been checked, in 14 yrs. I know that they are there to prevent gravity flow. Could this one valve, be my problem? Thankx0
I think that could be it. It may be stuck open partially and not seating correctly.
Most of the Flo-control valves have a manual override, lever or knob. You might exercise that a few times. If still flowing, then perhaps the rubber mallet hammer applied might seat things.
I would support one side with the left hand and wrack the right side with the hammer. If no mallet then a large rubber handle screwdriver or hammer handle. But never the actual metal hammer head. This secret technique has been applied for many repairs......just don't let the customer see you do it.1 -
Agree with @JUGHNE flow control valve is most likely leaking by0
Awesome!! I'll let you know . I have the Install/Oper/Serv instructions, so it looks like you can clean these things out. I'll prob have to get a rebuild kit or gasket, from supply house to rebuild.
Thankx0 -
The manual lever could have been moved part way to manual position. I would sure check that before a full drain down and opening up.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
