Difference in Fujitsu Models
charliechicago
Member Posts: 179
Hello to all,
I am giving a quote to a customer and wanted to know the difference between the 24RLXFW1 and the 24RLB? I've always installed the RLXFW model but when I got the quote from the supply house I saw it was a different model. I looked over the specs and I see there are differences but there is a large price difference and I need to explain to the customer so we can make a decision on which one he might install.
Thanks, Mike.
Thanks, Mike.
I am curious myself what the differences are as well.0
The RLX is just a bit higher seer. But most importantly is the operation temperature range is -5 for heating and not 14f like the RLB.0
Also I think the general features are different. The rlx i believe has the room sensor on the head to see if the room is occupied.0
- 123 Chimneys & Flues
