Infrared time-lapse of a steam radiator
Reinvent
Member Posts: 42
Made this video to show clients how a properly vented radiator looks as it fills with steam. Taken at 6 sec intervals for 23 minutes
https://www.youtube.com/watch?v=TgcTvNlOa8A
https://www.youtube.com/watch?v=TgcTvNlOa8A7
Loved the cat at the end.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg3 -
Cats always find the warm spots, I remember having a console color tv in the late 70's (mostly tubes). In the winter that's where the cat slept when it was cold. She was not happy when I put a cable box on top of it, more than once I found it teetering off the edge.
3PSI gauge0 -
Beautiful done! Thanks.Retired and loving it.0
I enjoyed that clip, thx!0
How cool is that? Thanks for sharing!All Steamed Up, Inc.
Consulting0 -
I added it to the Systems Help Center. Thanks!
https://heatinghelp.com/systems-help-center/watch-an-infrared-film-of-a-steam-radiator-getting-hot?stage=StageRetired and loving it.0 -
What is the floor finish?0
This video shows up after: steel vs. cast iron rad on hot water system.
https://youtu.be/JknpBPCAiiU 0 -
I honestly don't think we needed an expensive FLIR to show us that.Gordy said:
Mass is the entire reason I have an Ecosteam. Steam it self will allow the system to cool much faster than hot water once the burner shuts down but the 4000 pounds of iron in my house takes forever to cool.
But at the same time, mass can add comfort if controlled because it delays the heating and delays the cooling. Fast changes are bad, which is why forced air is what it is.
Would love to see one of those panel rads on steam though out of curiosity.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
