Infrared time-lapse of a steam radiator
Reinvent
Reinvent Member Posts: 42
edited March 2017 in THE MAIN WALL
Made this video to show clients how a properly vented radiator looks as it fills with steam. Taken at 6 sec intervals for 23 minutes
https://www.youtube.com/watch?v=TgcTvNlOa8A
BrewbeerSailahJohnNYRickBlackfordChrisJMilanDSteamedInWharton
  • Brewbeer
    Brewbeer Member Posts: 616
    Loved the cat at the end.
    Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
    System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg
    RomanGK_26986764589MilanDSteamedInWharton
  • BobC
    BobC Member Posts: 5,552
    Cats always find the warm spots, I remember having a console color tv in the late 70's (mostly tubes). In the winter that's where the cat slept when it was cold. She was not happy when I put a cable box on top of it, more than once I found it teetering off the edge.
    Bob
    3PSI gauge
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,690
    Beautiful done! Thanks.
    Retired and loving it.
  • flat_twin
    flat_twin Member Posts: 355
    I enjoyed that clip, thx!
    Steamhead Member Posts: 18,328
    How cool is that? Thanks for sharing!
    Consulting
  • DanHolohan
  • Gordy
    Gordy Member Posts: 9,546
    What is the floor finish?
  • MilanD
    MilanD Member Posts: 1,162
    This video shows up after: steel vs. cast iron rad on hot water system.
    https://youtu.be/JknpBPCAiiU
  • Reinvent
    It's an old fir floor with poly. Semi gloss I think. It is less shiny than the video would lead you to believe.
  • Gordy
    Proof of how mass of an emitter can enhance performance of the system.
    RomanGK_26986764589
  • ChrisJ
    ChrisJ Member Posts: 17,166
    edited March 2017
    I honestly don't think we needed an expensive FLIR to show us that.
    Mass is the entire reason I have an Ecosteam. Steam it self will allow the system to cool much faster than hot water once the burner shuts down but the 4000 pounds of iron in my house takes forever to cool.
    But at the same time, mass can add comfort if controlled because it delays the heating and delays the cooling. Fast changes are bad, which is why forced air is what it is.
    Would love to see one of those panel rads on steam though out of curiosity.
