ProPex fittings in Viega stainless manifold?
Harvey Ramer
Harvey Ramer Member Posts: 2,281
Anyone know if the propex loop assembly fittings work in a viega radiant manifold?
  • kcopp
    kcopp Member Posts: 4,636
    the fittings may not work but the tubing will fit in the manifold.. both are sdr9 tube
  • Hilly
    Hilly Member Posts: 429
    Uponor Manifold outlets are R20.
    Viega Manifold outlets are SVC.
    I am unsure of the thread differences there from a technical stance. I bet HR would have an answer to this one.
    hot_rod Member Posts: 27,037
    SVC = Standard Viega Connection.
    I'm not sure what thread that is, probably unique to Viega.
    Even if you found another connection that seemed to fit, thread pitch wise, it would not be a warrantied assembly, I suspect.
  • Hilly
    No wonder I couldn't find any information when googling SVC thread type.
  • Paul Pollets
    Paul Pollets Member Posts: 3,671
    the QS20 fittings will not work on Viega manifolds, or SBK.
  • JeffM
    JeffM Member Posts: 185
    Paul is right - these aren't compatible. The nuts should fit (I think they are all 3/4" straight threads), but that isn't enough. The diameters of the manifold end of the adapters aren't the same, so you can't get the connection to seal when mixing brands.
  • Harvey Ramer
    Thanks guys!
