High pressure steamers.
Timco
Member Posts: 3,040
Need to swap this 10hp with 15hp.
Suggestions on brand names?
Just a guy running some pipes.
Fulton or Lattner
Or Columbia0
Ok. How are you guys moving these out & in???Just a guy running some pipes.0
There usually on a channel iron skid. Pipe rollers would be one way depending on how much room you have to maneuver maybe a pallet jack0
Why are there 3 pressuretrol on that boiler?
Hi-Lo firing?--NBC0 -
cant tell from the picture but that is a Power Flame model J burner. They offer those in fixed fire, lo-high-lo or full modulation. Cant tell from the picture what that one is.
1 pressure control is probably an operating control, the other would be a manual reset safety high limit.
the third could be lo-high-lo or modulating control. If the burner does not have lo-high lo or modulating control the third control could be used for maintain a lower pressure at night or off hours (like a night setback)0
