High pressure steamers.
Timco
Timco Member Posts: 3,040
Need to swap this 10hp with 15hp.
Suggestions on brand names?
Just a guy running some pipes.
  • RJ_4
    RJ_4 Member Posts: 484
    Fulton or Lattner
    EBEBRATT-Ed Member Posts: 17,803
    Or Columbia
  • Timco
    Ok. How are you guys moving these out & in???
    There usually on a channel iron skid. Pipe rollers would be one way depending on how much room you have to maneuver maybe a pallet jack
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    Why are there 3 pressuretrol on that boiler?
    Hi-Lo firing?--NBC
    cant tell from the picture but that is a Power Flame model J burner. They offer those in fixed fire, lo-high-lo or full modulation. Cant tell from the picture what that one is.
    1 pressure control is probably an operating control, the other would be a manual reset safety high limit.
    the third could be lo-high-lo or modulating control. If the burner does not have lo-high lo or modulating control the third control could be used for maintain a lower pressure at night or off hours (like a night setback)
