How to Remove an Old, Threaded Fitting
HeatingHelp
Administrator Posts: 722
Don't try this trick on a malleable fitting, I think Boatbill means.
Malleable fittings will distort and crush. They will not break.0 -
Sorry to ask
Im very new in plumbing
But i have same situation with old black iron pipe
I need to disconnect them
Can i help myself with torch0 -
Thanks for sharing!!0
@Bill_Kitsch69 The 2 hammer thing works on malleable fittings, its just that you are not trying to crack the fitting, your are trying to break the bonds between the fitting and the pipe. I have successfully used this trick several times now. It just takes some patience and after walking the hammers around the joint the fitting will unthread easily. Most come apart in 5-10 minutes. The trick is not hitting it too hard, but just hard enough, you feel the backup hammer jump if you do it right.0
Likely hard to do on large fittings. But a propane/air turbo torch works nice on car rusted nuts, dull red. Used 3 of them on a car exhaust sensor once. For larger stuff used ~ 50k BTU propane/air ice melting touch..... outside.
Oxy-acetylened a car cast iron exhaust manifold yellow/white hot to remove badly rusted studs, rusted to toothpick diameter hourglass shape. Wet rag on stick applied to stud for max temp difference, watch the steam. But I needed to re-use the manifold0 -
If I can’t get it with a pipe wrench, then I use a sawzall cut pipe off clean then make three cuts inside just barely cutting into threads. Then use chisel and hammer. This works great especially if you have to thread something back in. You will have to use tape and dope though.0
During the first half of my working life I was a millwright and we often used dry ice on one side to rapidly cool large stuck parts. Just for the heck of it I'm planning to try CRC Freeze-Off on four 38 year old copper fittings to see how that works. Their ad says that it instantly cools to -60F. Would be really cool if it works!0
38 years isn't very long and copper doesn't usually seize...0
- 50 Industry Classes
