Pressure tank glass seals.
icy78
Member Posts: 404
Anyone got a link or info for replacement seals for hydronic pressure tank sightglass? I have not changed these before but the top one I am suspicious is leaking air out and thus water logging the tank.
Any supply house, the two valves on the gage glass should be closed except when checking the level . If they are left open it could leak air.
Ok thanks. Guess I should've said compression tank.☺ I haven't found just the seals. In fact I've only seen the glass and rods. Is it usually a kit or buy separately?0
@icy78
Looking 4 this?
Crown 70322 5/8" Gauge Glass Packing Nut Kit. This kit includes everything you need to repair leaking gauge glass valves in the field. https://smile.amazon.com/dp/B013ID4M40/ref=cm_sw_r_other_apa_SZNMybGE9Q75D-1 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
