LP Gas pressures chaging????
GW
Member Posts: 5,177
in Gas Heating
Got a stumper, we have a one year old Bosch KBR Lp boiler, these boilers have been rock solid. This job we've been back 3 times, each time the o2/co2 numbers are different from where we left it. Any propane people out there? Bad regulator on the LP? Thanks, Gary
Had it happen on a furnace. Propane company ended up changing reg at the tank and the intermediate regulator. Took 2-3 calls to get it right0
Ok yes I'll tell the ho we need some ilp co ntervention0
Could be they are freezing up as well...hard to tell without a guage on the system to see what's going on. Is it a twin stage regulator on the tank or a 1st and 2nd stage system?0
yes short hand for home owner, maybe I should type just a few more characters??
I;m sorry I didn't look at the regulator set up, I will need the lp co to go deal with it.
Thanks, Gary1
