Replacing Main Vent
PinkTavo
Member Posts: 64
OK...I have a Hoffman 4A right now. About 20 years old. Not sure that it is working well because my new radiator vents "hiss" too much, from what I understand. All radiators do heat very well. I was thinking of replacing this with a Big Mouth, but there may not be enough clearance, pipe to wall, to fit it in. I won't be able to just screw in the Big Mouth because the overall radius is much larger than the 4A. This is a small system. 210 Sq Ft of radiation. Would a new 4A work OK? I can't find its venting rate (CFM?). I posted last week, plan on adding a 2nd Main vent on the smaller branch this summer. Maybe two 4A's would work OK? Thanks for any help.
The beauty of the big mouth is you don't doing the whole thing to install. The tailpiece installs with a 5/8" hex wrench and the the vent itself installs on that. No need to spin the whole thing so it could be a good fit for your application. As far as overkill on a small system maybe, but when you compare dollars to venting rate I don't think any other main vent can touch it.
Edit: Height could be an issue, how much height do you have?0 -
@PinkTavo , that Hoffman 4A vents at .26 CTM @ 3 ounces of pressure. That's less than a Hoffman radiator vent set at 4 or 5. No way enough for a main. Use the Barnes and Jones Bigmouth. As @KC_Jones said, you don't have to spin the whole body, just the tailpiece which is about the same diameter as a 3/4" union.
If height is an issue (even though it looks like you have plenty height) use the Barnes and Jones Vari-Vent. It is shorter, probably about the same as that Hoffman, maybe a little shorter and about the same diameter and is about 10 times faster venting that the Hoffman 4A. The Bigmouth is about 14 Times faster.0 -
OK. Thanks all! I am ordering a Big Mouth as soon as I get off this post. Height should be fine....I can always cut out some off the drywall. I did see a post about a tail-piece using an 5/8" hex, but didn't quite get how it worked. I get it now. Am going to use the suggestion of a 5/8" bolt head....instead of buying a hex for likely just one use.0
