Beckett AFG oil burner puff of soot at startup
140,000 btu DOE is output and is based on 80% of input so the input would be 175,000 max. 170,000 divided by 140,000 = 1.25 gal. The best way to get 1.25 gal is with a 1,00 gph nozzle and 140 to 150#. Every flame retention burner has a solid air pattern. Can't imagine why anyone uses any nozzle but a solid.
Well for one reason is just because a nozzle says its solid or hollow doesn't necessarily mean it is.
When it comes to following manufacturers spec or following actual testing in the field, I am pretty sure testing wins every time.0 -
Open up your window and yell (or send a PM)...I'm in BroomallJay4334 said:@STEVEusaPA a few people have mentioned you for this area, where are you located?
Go for it Steve. I will be back in that area in March.0
I'll most likely see you at your class in Philly. Negotiating vacation with my wife!captainco said:Go for it Steve. I will be back in that area in March.
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
