Wanted to share these pics then I'll elaborate later.
Timco
Member Posts: 3,040
My only hope is that that boiler has been decommissioned.0
I am sure you know it but that boiler was put in that hole for a reason.
After seeing this though, a feeder pump with a large tank may solve both your problems......also a floor drain or sump pit pump.0 -
Think they call that a "tease".
It worked. Come back soon!New England SteamWorks
newenglandsteamworks.com0 -
Looks like the flood was a blessing in disguise0
Love the sump pump box in the distance
Ok. There's the East Cliff and West Cliff. SLC. WC used to have the boiler for both and a 4" line runs between the buildings. Sometime in the past each building got its own boiler and was sold as a separate property. Last year, WC burns. It's been unoccupied since. As I'm told, there's a huge dispute about who but someone at WC left a sump unplugged and the basement (almost 2000 sq' and 15'+ceilings) filled to the top. These basements are well below the sewer laterals and almost nobody installs a sump. Anyway, when it filled to the ceiling, EC was flooded via the 4" steam main that was never capped or anything. The tiny sump in EC never had a chance.Just a guy running some pipes.0
I'd like to stay gravity return but a feeder would indeed solve the return volume issue. I'm well aware of the reasons it's in the pit, everyone has asked now if it has to be down there.JUGHNE said:I am sure you know it but that boiler was put in that hole for a reason.
It's at the bottom of awful stairs. It's going to be terrible getting that out and the new in. It's considered a total loss with Smith's opinion. 32 units.Just a guy running some pipes.0 -
When I got there they had actually tried a new ignition controller. I was pissed. It's dead, Jim.Danny Scully said:My only hope is that that boiler has been decommissioned.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
