out on safety
lakota
lakota Member Posts: 32
oiled fired furnace goes out on safety every three or four days 10000 volts at transformer Hit reset at fires right up any ideas of what to look for
  • lchmb
    lchmb Member Posts: 2,997
    edited January 2017
    so many places to start...last tuneup done? have you checked your nozzle, filter, strainer? What is your pump pressure? What is your cad cell reading? How did you come to the conclusion you had 10000 volts at your transformer? What kind of control on the burner? What are your combustion readings?
    STEVEusaPA
  • billtwocase
    billtwocase Member Posts: 2,384
    So many possibilities. Need more info
