better regulator needed for Nitrogen tank,,,testing AC lines
GW
Member Posts: 5,183
Any ideas on a good regulator for the nitrogen tank- testing systems? We have gone through a couple in the last two years, we don't use them everyday, not even close.
We test to 600, is there a better regulator that goes well beyond 600?
Our local Webb branch has a basic unit that goes to 600, yet we have to crank the stem all the way.
Thanks, Gary
Thanks, Gary
The Uniweld RHP800 does up to 800. My Uniweld 400 will do 450 balls out. Not sure how these hold up over time though mine was bought originally to do 20 psi
https://www.amazon.com/Uniweld-RHP800-Nitrogen-Regulator-Delivery/dp/B00GYGJUQ4GW said:Thanks Chris, I shall google that
Curious GW, what requires a 600 PSI test? I thought most guys did a 400-450 PSI test on 410 systems?
Ah I see.GW said:Mitsubishi is 600
There's also a 0 - 1500 PSI regulator on Amazon, but it's almost $340, I have a feeling it's not near worth it.
https://www.amazon.com/Thermadyne-Firepower-0781-9726-FSH4-1500-580-Regulator/dp/B007VWKMSK/ref=sr_1_2?ie=UTF8&qid=1483640465&sr=8-2&keywords=1500+psi+regulator
no that 800 should be ideal, thanks. As our other ones die we will get the beefier unit (we have just 3 set ups)1
- 123 Chimneys & Flues
