Exhaust vibration
bmcd1023
Member Posts: 1
Four years ago we had a Burnham Alpine Gas Boiler installed. Since the installation the exhaust has had a vibration with a hollow sound. After reading up on the problem, I realize it is running lean and needs a combustion test. We cannot find a service technician, after trying several, that know how to run the test and correct the problem.
Do you know of anyone in the Cape Cod area that knows how to adjust the boiler.
Please advise.
ekmcd@comcast.net
Please advise.
ekmcd@comcast.net
You could call your gas supplier. But, I would prefer you find a pro from this site if you can.0
Well it's a simple gas pressure adjustment.or a swirl plate problem...What's happening hen it lights off it is making a slowly disappearing vibrating noise or is it a howl.you hear?0
Either case generally simple.one needs a gas monometer,and a combustion analyzer...With a due date for calibration clearly labeled...0
