Reverse Cycle Chiller Question
jb9
Member Posts: 104
Hello,
I am confused about the difference between an air-to-air source heat pump and a reverse cycle chiller. Why is a reverse cycle chiller used in radiant applications while the air-to-air source is used mostly in ductless mini-splits? I sense this is a dumb question but I am going to ask it anyway.
Thanks.
Thanks.
An air-air heat pump uses finned refrigerant coils to heat or cool the air directly by heat transfer from the refrigerant.
A chiller heats or cools water and transfers heat between the refrigerant from the refrigerant to the water through a shell & tube or plate & frame heat exchanger.
Chillers use water for a heating medium the same as a radiant system does.
air-air heat pumps use air the same as a ductless split does.
There's no stupid questions were all learning
Got it. So is the reason that a reverse cycle chiller unit is more expensive is because it is a more complex piece of equipment due to the extra heat exchanger piece? Also, are there fewer of them produced and installed than air-to-air source heat pumps?0
Thanks K. I thought that might be it.0
When I read the title I was thinking of a Trane CVHE running backwards or something .
Reverse cycle chiller , a few years ago we called them water to water heat pumps. But " Reverse Cycle Chiller " sounds important . Heck , you would think that it sounds more technical than Trane CVHF or even " Centravac " . So a water source heat pump is a reverse cycle chiller when viewed from the condenser loop side. More coffee maybe , till then it's bunk.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
Wouldn't you call it an air to water heat pump?0
Or a reverse cycle air conditioner.
I guess the terminology issue is mine , I'm just used to a chiller being a larger machine. A small machine that cools water is in fact a " chiller ". Terminal equipment none the less.hvacfreak
Air to water, that's what I'm familiar with. Heat pump with water on the condenser instead of air.0
