Question about fuel usage on single pipe steam
NewbieInQueens
Member Posts: 25
HI everyone, I am trying to understand my natural gas consumption as it was pretty high last month!
In terms of the amount of gas my boiler burns, is that strictly by the number of hours? For example 1 hour will burn xxx amount of therms? Or can the gas usage per hour vary based on higher/lower pressure, cycle run times or other variables?
Thanks and Happy Holidays,
2 variables that can affect your usage areNewbieInQueens said:HI everyone, I am trying to understand my natural gas consumption as it was pretty high last month!
Thanks and Happy Holidays,- If you have a hi/lo 2 stage setup
- Short cycling
-1 - If you have a hi/lo 2 stage setup
There are plenty of good Steam Men in the NYC area who can help you get your steam system to use less fuel. Go to Main Site, then Find a Contractor and follow the instructions.All Steamed Up, Inc.
Consulting0 -
Simply put natural gas is measured by the cubic ft thru the meter.....The fuel burn will not change on the boiler...how long it runs so satisfy the thermostat is another thing....This is assuming your boiler is in good shape and installed correctly...Post a picture...That will tell the folks here a lot.....Also do this....While all other appliances are off, don't worry about the pilots running....Then get the boiler up and running,let it run for a bit,this is called the steady state condition,the go to the gas meter, look for the 1/2 cubic foot dial,usually bottom left of the dials, set your stop watch to start when the dial is at 12 o'clock after one revolution stop your stop watch...this is called clocking the meter, report back your seconds per one revolution and some one here will tell you the attached load...it should closely match your boilers input when converted to BTUS....pretty simple ha....
1
