Main vent valves for low vertical clearance?
fnf
Member Posts: 3
It's a two main 1-pipe steam system with one of these vents (pic attached) on the end of each. One of the valves is stuck shut so I'd like to replace both, curious if anyone knows of a nice vent that will fit in here? Vertical hight doesn't seem to be specified on a lot of the ones I've looked at. There is just under 4" of room
thanks
thanks
I should mention: threads are 1"0
You could always mount the new vent on the underside of the 90 degree ell, on the vertical pipe.
Do a search for the big mouth vent here, and it will give the dimensions.--NBC0 -
Big Mouth Is 4 3/4" overall.
The vari vent is 3 3/4" tall overall. Probably best option. But it's only 1/2" NPT so you'll need room for a bushing. It would be close.Peter Owens
SteamIQ0 -
It would be a nice excuse to put in a tee with a pressure gauge, I'll look in to the big mouth thanksnicholas bonham-carter said:You could always mount the new vent on the underside of the 90 degree ell, on the vertical pipe.
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
