Taco circulating pump
I have a Taco 006-ZB4-4 circulating heater. It gets too hot to touch and doesn't seem to be pumping. No noise and pipes are not hot beyond it. I removed it to see if it was maybe bound up but seems to turn easily. Can I get away with replacing just the cartridge or are the coils no good? How can I test it? I don't want to buy a cartridge then find out I need a whole pump.
Are you sure the system is free of air ?0
Should be. There was lots of water in it when I removed it. How do I bleed the air if it isn't pumping? It's all crimped pex pipes. The pump is for the in floor heat in the garage. There is a separate pump for the basement pump that seems to be working good.0
I've tried tapping it and the switching it on and off. No luck. I should correct myself. The piping get used to run in the floor in the garage but it had frozen on the previous owners so the ran the water through a radiant heater instead. The pipes feel Luke warm in and out. Even if there was a blockage wouldn't the pump still try to turn? There is nothing, even with the pressure bled off0
Bad capacitor?All Steamed Up, Inc.
Consulting0 -
I think you are going to need to pull the pump apart to see if it is jammed, broken, air locked, etc.Mac13 said:I've tried tapping it and the switching it on and off. No luck. I should correct myself. The piping get used to run in the floor in the garage but it had frozen on the previous owners so the ran the water through a radiant heater instead. The pipes feel Luke warm in and out. Even if there was a blockage wouldn't the pump still try to turn? There is nothing, even with the pressure bled off
The 80 w of energy going to the pump becomes heat if the system is unable to circulate, that is one reason they get smoking hot to the touch. When circulating properly they should be close to the temperature of the fluid moving through them.
Purge valves installed? that would indicate if the system can flow. If water, free of air, circulates around by filling and purging, the last option is the pump has failed.
If you shop around you can probably find a new pump for about the same, or less than a replacement cartridge.
Taco - 006 - I would just get the whole pump. You can just replace the motor and cartrige and leave the old housing if that is easier, but either way its just 4 bolts.
The new pump VS cartridge only is a very minimal price difference. Get the pump and at the very least you can rule out the pump as the cause of the problem - but Id say its 90 percent likely to be the issue.0 -
Replace the circ. A smoking hot circ is a sure sign that a replacement is needed. Put some valves on each side of the circ for easy change out for the next time. this is pretty common. Good luck.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
