a little propress
you didnt mark your fittings to indicate proper stab depth...(had to find something for you..nice neat job)
well, there is a boo boo, but I know it before I did it. on the far right the hot is on the right. I just went out a little further then straight down. I didn't feel like doing anything tricky with the piping , plus there going to washing machines.0
Nice piping.
You can buy press/ hose valves nowadays, save some bucks and all the threaded connections. Here is the Apollo version.
I prefer the rubber insert type unistrut clamps, it allows some expansion and contraction movement.
What about water hammer arresters. Quick acting solenoids re notorious for banging piping.
hot rod , I rather have I.P. that way if the ball valve gets seized i can just unscrew it and add a new one. when I asked for these valves the supply hose wanted to sell me what you posted. If I had to install hammer arresters where would I put them.0
here is some good info on hammer arrestors
http://www.jrsmith.com/uploads/fileLibrary/pm2049.pdfBob "hot rod" Rohr
- 50 Industry Classes
