a little propress
Snowmelt
Snowmelt Member Posts: 1,454
I'll take some criticism
  • lchmb
    lchmb Member Posts: 2,997
    edited December 2016
    you didnt mark your fittings to indicate proper stab depth...(had to find something for you..nice neat job)
  • Snowmelt
    well, there is a boo boo, but I know it before I did it. on the far right the hot is on the right. I just went out a little further then straight down. I didn't feel like doing anything tricky with the piping , plus there going to washing machines.
    hot_rod Member Posts: 27,492
    Nice piping.
    You can buy press/ hose valves nowadays, save some bucks and all the threaded connections. Here is the Apollo version.
    I prefer the rubber insert type unistrut clamps, it allows some expansion and contraction movement.
    What about water hammer arresters. Quick acting solenoids re notorious for banging piping.
  • Snowmelt
    hot rod , I rather have I.P. that way if the ball valve gets seized i can just unscrew it and add a new one. when I asked for these valves the supply hose wanted to sell me what you posted. If I had to install hammer arresters where would I put them.
    here is some good info on hammer arrestors
    http://www.jrsmith.com/uploads/fileLibrary/pm2049.pdf
