Dunham Bush unit heaters
Chuck_17
Member Posts: 148
Does anyone have access to 80's-ish Dunham Bush hot water unit heater capacity data?
Specifically:
H-250-C
H-400-C
H-500-C
Specifically:
H-250-C
H-400-C
H-500-C
No but it looks like they gave it to you. H-250-C is probably 250,000 btu/ hour.
Probably has 1 1/2" pipe on the 250, 2" on the 400 and 2 1/2" on the 5000 -
Perhaps the steam capacity.0
Consulting1 -
Thanks.
As far as I can tell from their 20th century website , they don't have unit heaters. I'll keep looking.
The space the unit heaters are located is a basement church hall. The 250 is probably more than enough using 180 deg water. There is also a 500 and two 400s.0 -
mepco does not have hydronic unit heaters. DB of Americas out of florida does according to the rep at mepco.
I see nothing on the D/B website. I would get the model #, pipe size, fan HP and the dimensions of the coil and go to Sterling, Modine or Beacon Morris and have them match something up.
Dunham Bush used to be a big player now they moved off shore and don't do much in the US as far as I can tell0
