Low water cutoff got wet! What do I do??
kalindaminda
Member Posts: 9
The heater suddenly stopped working on the first snow day of the season. When I went to check it out, I saw water dripping steadily onto the low water cutoff.
After turning off the switch and cleaning up the water, I opened the cover and saw what looks like foamy water tracks on the circuit board inside. Any options??
Yeah haha but I was hoping for a miracle. Can I buy a new LWCO and replace it myself?Hatterasguy said:You probably know the answer already.
Nobody can ever say with certainty that an electrical control is reliable after contamination by water. If you dry it off thoroughly and it works today..........will it work tomorrow?
It was positioned directly beneath a pipe and the pipe was leaking. If I turn the switch back on, it tries to start, but sputters and turns off with the LWCO blinking red.Boon said:What is/was the source of the dripping water?
And is it working again, do you have heat now?
At the moment, no it's not working, and the heat won't turn on.
Google, here I come.Hatterasguy said:
Of course, if you're a bit handy with the wires. Turn off the power first.kalindaminda said:
Thank you, good sir lol I'll try not to shock myself
You are my savior! I'll be very very careful. Thank youuu
Mums the word!0 -
Ah... that's a good point. I haven't actually fixed the leak yet. I'll focus on that first.Boon said:Ok, I was wondering if the leaking pipe was boiler piping.
did you check the water level on the boiler? Maybe the LWCO is blinking red for a reason0
I checked, and it's all good.adambnyc said:did you check the water level on the boiler? Maybe the LWCO is blinking red for a reason
@Hatterasguy
Fortunately it didn't come to me having to implement your quick-fix, as I only understood your suggestion in theory haha
Once the control dried thoroughly it started working again (for now). I also fixed the leak that soaked it in the first place.
The next thing is to replace the lwco and find a way to position it so it's not directly underneath a valve...0 -
Thank you to everyone ❤️❤️❤️0
It amazes me that these controls don't use humisealed boards. That would make them just about impervious to incidental water spills.
I understand it will never happen because it probably costs a nickel to humiseasl a board.
3PSI gauge1 -
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
