How's the near-boiler piping?
nybigapple
Member Posts: 61
Anything egregiously wrong?
Equalizer looks too small, riser is too short. Should be 24" min above the water line. Boiling water jumps. A lot of the pros are going for 36" risers. I see your under space constrains, this is a great place for a drop header.0
How easy would it be for a professional to add a drop header? Could it be added easily enough to the existing piping or would it require complete repiping?0
Let me ask in another way. How long do you think it would take a typical professional to add a drop header(if there aren't any problems)?
I'm trying to decide if I should look into getting some things done now, or hold out till after winter is over. My main concern is being able to finish it within the course of a day without issue.
Would require a complete repipe. Before a repipe is proposed I would see if that boiler is properly sized and then go from there.0
Ah that's the piece I was looking for. A complete repipe means I won't even bother looking into it till after winter. Thanks!0
Bullheaded riser take-off on top of all that.0
a complete repipe may be cheaper than the extra fuel and discomfort you'll have this winter... It would make for a long day but betting with prep it could be done in one day...just have coffee ready at 6am...0
g
Smart move, got some visible issues there.....maybe when you start getting proposals you can post them here.....less pricing of course..We will give you 3 or 4 basic questions to ask him about steam....If he can't answer them he may not be your man...nybigapple said:Ah that's the piece I was looking for. A complete repipe means I won't even bother looking into it till after winter. Thanks!
Before you start looking into repipe
1- Does it work now?
2- How old is the boiler?
3- Have you done the basics yet? - washout (fire and waterside)
I would not advise doing a repipe unless the boiler was 5 years old or less unless the existing piping is somehow preventing heat function which I doubt.
Repipe when the boiler is replaced, for now insulating the piping will reap you cheap and easy (you can do yourself or with cheap labor) rewards in fuel consumption.0
- 87K THE MAIN WALL
- 58 Biomass
- 112 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
