Today's Kodak Moment: Uhhhh, Beavis- will these vents work?
Steamhead
Member Posts: 18,454
Looked at this steam system today. Someone had replaced the main vents in the not-too-distant past.............
Consulting
Consulting
5
These were relatively short mains, so I installed Gorton #1s and added a riser to the one that didn't have it. It vents much more quickly now and doesn't leak steam.
Sometimes, all you can do is shake your head and get out the wrenches.All Steamed Up, Inc.
Consulting0 -
Well yes that is silly... but at least they knew a vent needed to be there and didn't just plug it.0
Both the air AND the steam.Solid_Fuel_Man said:Those auto vents let all the air out till water reached them right.....
Consulting2 -
The steam has to get out so it can heat the area right?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
That must be it... huh-huh.... huh-huh.... huh-huh
Consulting1
- 50 Industry Classes
